Photoetched-metal cutting mat
RELATED TOPICS: MODELING TOOLS
I have read FSM tips about holding photoetched-metal frets with tape while cutting so the parts don’t fly away. This has happened to me, but I believe I have found the answer to this problem — tacky beading mats from Beadalon. I found mine at a local craft store. It is a 41⁄4" x 41⁄4" blue gel mat.
I gently press the fret onto the mat, making sure it is flat. Then I carefully cut the part from the fret using a new No. 11 blade, making sure to not cut too deep into the mat. I use a wet cloth to wash the mat, and the cut seems to close naturally. It appears that if you do not cut too deeply into the mat, the incision will heal.
Tip submitted by:
Russell BootsVinton, Iowa
SUBSCRIBER-ONLY CONTENT
FREE GUIDE DOWNLOAD
Expert how-to advice!
