Have you ever super glued your fingers together and run out of debonder? It happened to me while super gluing photoetched-metal pieces to a Panther tank. If this happens to you, do as I do: Reach for a brush and lacquer thinner, smear the lacquer thinner on the bond, work it into the area, and slowly pull your fingers apart. The lacquer thinner will dissolve the super glue, and you’ll be able to go out and get some more debonder.
Tip submitted by:Ernesto UrtiagaOviedo, Florida
