Use foam rubber to block off view through a fuselage
RELATED TOPICS: DETAILING
To close off an empty fuselage and block the view through the canopy, use a block of foam rubber slightly larger than the fuselage cross-section. A few drops of white glue will hold it in place as the fuselage  halves are joined. The foam expands to fill the void.
Tip submitted by:
Chuck LeniekEndwell, New York
Airbrushing acrylics
Tests, tips and techniques.
