Ever have super glue caps stick and need to use your pliers or Gerber tool to loosen them? Sometimes you just can’t take them apart.
Acetone is the answer. Fill a little cup with acetone just above the cap and soak it for about 30 minutes.
Bam! You’ve got a cap with no glue on it. Just wipe it clean and stick it back on the glue container. Use a spare glue cap temporarily while soaking the other cap.
Problem solved!
Tip submitted by:
David Holman
Central Point, Ore.
