Tamiya 1/24 scale McLaren Senna plastic model car kit
The parts fit of this McLaren Senna car kit will astound you
RELATED TOPICS: AUTO | TAMIYA | SENNA
01TamiyaSenna
I painted the rear framework with Alclad II duraluminum then masked and painted semigloss black. Then I brush painted the neutral gray for the mats and aluminum for the upper A-arms.
02TamiyaSenna
The engine is relatively simple to build, but the detail is quite good.
03TamiyaSenna
Exhaust was done with Alclad II titanium gold and the block is painted dull aluminum.
04TamiyaSenna
The brake discs are separate from the calipers and will rotate with the wheels. Testors gunmetal buffing metalizer is a good match for the carbon-ceramic discs.
05TamiyaSenna
After initial cleanup and test-fitting, parts are grouped by color for painting. Stock up on your favorite semigloss black, because you’ll use lots of it!
06TamiyaSenna
The front suspension and some interior bulkheads have been added.
07TamiyaSenna
I used blue on the shocks just to add a little color; maybe not technically correct, but that’s the beauty of modeling, you can do it how you like!
08TamiyaSenna
All the padded parts of the seat are individual parts, which makes painting a breeze. I deviated slightly from the instructions using Tamiya metallic black (TS-40) for the shell and rubber black (XF-85) for the pads to try to get a little color separation from the rest of the interior.
09TamiyaSenna
The engine has been installed and the rear suspension added. Take care when adding the rear links (Step 34, parts C25): They set the rear toe. I seem to have just a touch of toe-in on mine.
10TamiyaSenna
11TamiyaSenna
The dash too is separated into several parts to simplify painting. There are decal options for the main display and info panel. The dash can be positioned in full or slim display mode.
12TamiyaSenna
The body panels attach to a main skeleton. The center section has been painted gloss black and masked and then sprayed with semigloss black (TS-29). I used Parafilm for masks because it is easy to fit around the complex shapes.
13TamiyaSenna
Talk about a multipiece body! I picked brilliant orange (TS-56) because it’s reminiscent of Can-Am cars. Three coats give a nice color depth. Just a little polish gets out the inevitable dust bunnies.
14TamiyaSenna
Complete except for the wheels, the chassis is ready for final assembly. Fit is incredibly precise throughout, and detail is very good.  Too bad much of this is going to be hidden once the body is attached!
15TamiyaSenna
No glue is used to attach any of the clear parts. Instead, they are cleverly captured by either body panels or other trim pieces, so no worries about mishaps. With the rear fenders added it’s starting to take shape!
16TamiyaSenna
17TamiyaSenna
18TamiyaSenna
19TamiyaSenna
24TamiyaSenna
20TamiyaSenna
21TamiyaSenna
22TamiyaSenna
23TamiyaSenna
In the mid-1990s, McLaren cars introduced what many consider to be the finest supercar made, the McLaren F1. Its latest entry in the supercar field may be even a little more extreme. Named after legendary driver Ayrton Senna, the McLaren Senna is more track focused with maximum performance taking No. 1 priority over driving experience. Only 500 examples will be made, so they will be a rare sight indeed.
Tamiya has been in the habit of springing some surprises on us of late, and the McLaren Senna came as a total shock. The new kit can be built to European, US, or Japanese spec versions and features a complete detailed chassis with engine, metal transfers for emblems, and an accurate reproduction of all the aerodynamics integrated into the body. I counted nearly 250 parts altogether: chassis parts molded in black or silvery gray and body parts in white. The instruction booklet breaks down the assembly into 50 clear steps and even has a full-color addendum with some useful reference photos. (I find eBay motors is a great place to find detail shots, too.)
Basically, construction consists of two major assemblies — the body and the chassis — and then combines the two. The instructions start you off with the body which begins with the main “skeleton” on which the rest of the body panels attach. First to attach are the radiators and associated ducting. Clear parts come next. The glass roof panels need to be tinted with Tamiya smoke (TS-71) smoke (I gave my lower door windows some tint as well). All the clear parts are installed without glue! Instead they are captured in place by body panels or trim pieces so there’s no worries about mishaps.
Most of the body panels are subassemblies each requiring multiple parts to accurately depict the car’s complex shape and ducting. Most people cringe when they hear “multipiece body,” but don’t worry. The fit of the parts and the way they are engineered to go together is nearly fool proof. Trim pieces are separate, so there’s no need to mask anything. Just paint and glue in place! The body takes shape pretty quickly once you start attaching the different panels to the skeleton. Again, the fit is astoundingly precise, so be cautious of paint buildup as it may affect fit.
The chassis too has a main central component that everything else attaches to. The front suspension comprises 15 parts in total. Front wheels are steerable and the brake rotors and calipers are separate so the rotors will turn with the wheels. The twin turbocharged V8 engine is really simple to construct despite its complex appearance. Once installed and with the finished rear suspension, it looks incredible. Too bad it’s nearly completely hidden once the chassis and body are mated.
Seeing that it is mostly carbon fiber, simplicity in paint and assembly carries over to the interior. All the padded sections of the seats are individual parts to aid painting. The different colored sections of the dash and door panels are separate too. Optional displays for the main dash panel and info panel are provided as decals. Surprisingly, you will need to add your own seat belts, if desired, as they are the only thing missing.
Like the Senna for it's quick lap times, Tamiya has always had a reputation for high-quality, precision, model kits, and this kit, without a doubt, cements its spot at the tip top of the list. I could spout superlatives all day long, but suffice it to say the McLaren Senna is truly a phenomenal model. It comes with my highest recommendation!
FREE DOWNLOAD
FREE DOWNLOAD
