Despite all the many panels involved, the cockpit fits well with a bit of encouragement – there’s a lot going on with fitting all the bulkheads and the many internal details. I apparently mounted the front bulkhead just slightly too far forward, which caused difficulty in aligning and joining the nose section to the rear fuselage and resulted in a seam – a bit of filling was required as a remedy. After mounting the wing and the upper fuselage cover, I found a small gap just in front of the cover; a little sheet plastic and filler took care of that.
