After installation of the radiator and associated plumbing the engine is basically done. There are a couple of pipes that are nearly impossible for anyone with adult fingers to maneuver into place. One set apparently needs tweezers with 6 degrees of movement and a rotating head. I cut the tubes off where they disappear behind the engine mounts. Shhhh … I won’t tell if you don’t!
