A scanner clearly
Anyone who uses a flatbed scanner to copy and enhance instruction sheets may get the reverse side of the sheet against their will. An easy fix: Cut a sheet of black construction paper to the size of the bed and lay it over the instructions. The scanned image will be dark but is easily lightened with the scanner program’s adjustments.
Tip submitted by:
David ErskineMetamora, Michigan
Related topics
