Incense for tighter wiring
In FineScale Modeler’s October 2007 article “Stretching sprue,” Aaron Skinner used a glowing match to tighten stretched-sprue antennas or rigging. The extinguished matches don’t provide an even heat, so you’ll need a lot of matches for a model with several rigged lines. Instead, I recommend using incense sticks (easily found at craft stores). These scented sticks light easily, hold a glowing ember, and heat up with little effort (just blow on the tip). The stick’s length allows you to get into tight spots on the smallest of 1/72 scale models. Plus, they smell better. (I had been using cigarettes, but I stopped smoking several years ago.)
Tip submitted by:
Byron J. WyssFort Wayne, Indiana
Related topics
