Making wire coils
To make accurately uniform wire coils, wrap wire around the threads of a screw or bolt, then slowly turn it to remove the coil. Partially removing the coil and continuing to wind will give you any length you need. Spray a little WD-40 on the screw first to make it easier to remove the coil.
Tip submitted by:
Bill ThibautDonaldsonville, Louisiana
Related topics
