Judicious use of super glue
I’ve found a good way to work with super glues. First, cut a 4″ length of duct or masking tape and stick it on a hobby cutting mat. Put a drop or two of super glue on the tape. Use a micro-applicator to transfer a tiny bit of super glue to the desired attachment point. Use your finest-tipped tweezers to place the part you want to glue. When you are finished gluing, cut a square around the drop (or drops) of glue and throw away the cutout. This technique goes a long way toward applying minimal amounts and conserving your supply of super glue.
Tip submitted by:
Lavarre UhlkenSycamore, Ill.
Related topics
