More thoughts on storing, packing
In a recent issue, a question was raised about how to store or pack models. I have been building models again since 1995 and must store most of my built kits that I cannot display. Here’s what I do — and it works.
I use a simple box; the size varies. I shred newspapers into small strips and carefully place the models into the box in layers and cover the models carefully with more shredded newspaper. I layer about five or six 1/72 scale aircraft this way, or 1/48 scale aircraft, depending on size and type.
At the top of the box, after the models are covered, I add one more layer of shredded paper, then label the contents on the box top and tape the lid shut. This method also applies for 1/35 scale armor, except fewer armor models can be stored because of their size.
I also use this method when I take models somewhere for a show-and-tell session.
While periodically there is damage, a broken landing gear or antenna, those are simple to repair. I also secure canopies with small pieces of construction clay when storing a model.
Hope this helps someone!
Tip submitted by:
George Lewis Fugett
Hixson, Tenn.
Related topics
