Glue mixing tips
I use a Post-it note pad as a disposable mixing surface for 2-part epoxy. I mix the epoxy on the top sheet. When I’m finished, I let the remaining epoxy harden, then just peel off the sheet and throw it away. You also can use a smooth tile to dispense glue into a small puddle and apply it to your model with a tool or toothpick. Once the glue hardens, scrape the remainder off with a single-edged razor blade!
Tip submitted by:
Dennis Rossko
Carollton, Texas
Related topics
