Stop the corrosion on figures
A common problem with poorly-prepped figures was a kind of corrosion that would, after a year or two, bubble the paint off. The solution was simple: Soak the metal in a bath of white vinegar overnight. Next, prime the figure in enamel or lacquer (not acrylic). I always preferred the now-unavailable Floquil primer, but any…
If you’re building a kit with metal (not photo-etch) parts, make the finish last with this tip I learned way back in the 1970s, when most 1/35 scale figures were lead (also known as pot metal).
Back then, a common problem with poorly-prepped figures was a kind of corrosion that would, after a year or two, bubble the paint off. The solution was simple: Soak the metal in a bath of white vinegar overnight. Next, prime the figure in enamel or lacquer (not acrylic). I always preferred the now-unavailable Floquil primer, but any enamel or lacquer will work.
I still have figures from the mid-70s that have never suffered from corrosion. So, if you’re using metal landing gear, propellers, or other parts, try this old but faithful tip.
Tip submitted by:
Ned Barnett
Las Vegas, Nev.
Related topics
