Matthew Walker’s Rafale B
If you build modern military aircraft, you’re going to end up with a lot of gray planes. But closer examination shows that camouflage is rarely uniform. The paint weathers quickly, shows stains, and is often roughly repainted by hurried ground crew. Matthew Walker’s French air force Rafale B shows that wear and tear.
FSM-AB0415_05
If you build modern military aircraft, you’re going to end up with a lot of gray planes. But closer examination shows that camouflage is rarely uniform. The paint weathers quickly, shows stains, and is often roughly repainted by hurried ground crew. Matthew Walker’s French air force Rafale B shows that wear and tear. He achieved the finish with a combination of pre- and post-shading.
FSM-AB0415_06
FSM-AB0415_01
FSM-AB0415_02
FSM-AB0415_03
FSM-AB0415_04
FSM-AB0415_07
FSM-AB0415_08
Related topics
