Workbench Review
Airfix 1/72 scale Supermarine Spitfire PR.XIX
As Airfix continues to recover from its 2006 bankruptcy, it is introducing a line of new 1/72 scale aircraft, including this Griffon-engined photo-reconnaisance Spitfire.
72 scale supermarine spitfire pr.XIX 1
  • Kit: A02017
  • Scale: 1:72
  • Price: $8.50
Airfix
New subject; optional parts
Minor fit issue; no cockpit instruments or cameras; soft detail; decal silvering
Injection-molded, 43 parts, decals for two aircraft
The Spitfire is a favorite of aviation buffs all over the world, and it’s always been a popular modeling subject. Airfix has found a gap in the roster of available Spitfire kits, producing a photo-recon version. The kit has a wheels-up option, a pilot figure, a separate rudder, and markings for postwar British and Swedish aircraft.
Upon initial review, I noticed the surfaces of parts were not smooth. I took care of the rough spots with a polishing stick, and filled a few sink marks with Tamiya primer.
The cockpit is built up from four parts. No instrument or seat belt detail or decals were provided. I painted the interior and the side walls Testors RAF interior green and used flat black for the instrument panel.
Gluing the fuselage, I noticed a hole in front of the cockpit that has no purpose. I filled it in. The seams were easy to clean up, especially with the plastic being somewhat soft. Choose any position for the rudder.
The wings have a front seam to clean up; after I had assembled them, I filled small gaps between the wings and fuselage. There was no positive location for the navigation lights, and I found the windows for the cameras were undersized. I filled those gaps with white glue.
Color references are expressed in Hum-brol colors. I painted the model overall with Testors RAF P.R.U. blue, the prop with Testors interior black (with flat yellow for the tips), and the spinner Testors flat red. I chose markings for 1 Division, Flottilij 11, Swedish air force, 1955.
Since I have not made an Airfix model in several decades, I wanted to see how well the decals would lay down. They did conform, but they silvered by the next day. So they will need a gloss coat first.
My main reference, The Hamlyn Concise Guide to British Aircraft of World War II, by David Mondey (Chartwell, ISBN 978-0-7858-1362-0), indicated the model was, if not dead-on, very close to scaling out correctly. It was a fun 10-hour build, and the price can’t be beat. If you’re looking to add another “Spit” to your collection, this is an easy way to do it.
72 scale supermarine spitfire pr.XIX 2
72 scale supermarine spitfire pr.XIX 3
72 scale supermarine spitfire pr.XIX 4
72 scale supermarine spitfire pr.XIX 5
72 scale supermarine spitfire pr.XIX box
More about
