Creating scale fabric
I have long sought the best way of creating “scale” fabric. Others have recommended tissue and diluted white glue, but I found that too fragile. Then I took a stab at treated computer-screen wipes, and found them ideal.
But I wasn’t satisfied, so I moved on to medicated skin-cleaner sheets and wet wipes. They work well and, with different weaves, each has its own uses.
I dry the sheets, then do one of two things: To cover solid forms (such as sheets on a medical stretcher), I use white glue or carpenter’s glue to fix the fabric to the plastic object. Or, when I need specific shapes, I use Woodland Scenic’s “scenic cement,” soaking the fabric before draping it over a form. When it’s nearly dry, I pull the fabric away from the form; the fabric retains its shape. I find this useful when creating rigid, draped fabrics.
I keep discovering new ways to use this material. I bet you will, too.
Tip submitted by:
Ned Barnett
Las Vegas, Nev.
Related topics
