Archives: Tips
Homemade pastel jig
Next time you need ground-up pastel chalk for a project, first make this pastel jig. You will need the following items: drywall screen, ¼” or larger wood square dowels, and super glue.
Render the rubber blocks found on tracks
Here’s a quick, simple, effective way I’ve found to render the rubber blocks found on tracks of modern armored vehicles.
Creating an aotake finish is easy
Japanese aircraft from the World War II era had wheel bays finished in an anti-corrosion paint known as aotake, a bright metallic blue that creates quite a dramatic effect.
Jewelry parts for modeling
The items are from Lisa Pavelka and are available at http://store.lisapavelka.com/. Useful for all types of model building projects, they are actually intended for making “steampunk” jewelry and include packages with watch guts of every shape, size, and description.
UV light quickly dries plastic
Enter Bondic liquid plastic weld, a clear plastic that dries in four seconds using UV light. This product is amazing for modeling!
Airbrush cleaning made simple
I have found a useful tool for cleaning my airbrush’s passageways — a dental pick. You can find these at a grocery store, drugstore, or most discount chains that sell dental products.
Better strutting
Gluing two struts onto a wing and getting them to allign properly can be a challenge. I build primarily 1/48 scale aircraft but my technique works in any scale. Patience is required; we all have that, right?
