Product
Bell X-2
By Peter E. Davies
FSMNP0418_23
Comments: Softcover, 80 pages, 42 black-and-white and 26 color photos, 7 color plates
ISBN:
978-1-4728-1958-1
Price:
$20
Publisher:
Osprey Publishing
From the publisher: Even before the spectacular success of its X-1 rocket-powered aircraft in breaking the sound barrier, the adventurous Bell Aircraft Corp. was already pushing ahead with a parallel project to build a second aircraft capable of far higher speeds. The X-2 (or Model 52) explored the equally uncertain technology of swept-back wings. Now common in modern conventional fighter aircraft, the Bell X-2 was revolutionary in using this type of airframe to probe Mach 3 and research the effects of extreme aerodynamic friction heat on airframes.
Although both X-2s were destroyed in crashes after only 20 flights, killing two test pilots, the knowledge gained from the program was invaluable in developing aircraft that could safely fly at such speeds. Artwork and historical photographs tell the story of the plane that ultimately made the Lockheed Blackbird possible.
FSM says: Especially useful to modelers will be the over/under views of aircraft details, its attachment to B-29 mother ships, and a text-keyed color illustration showing cockpit and instrument panel.
FSMNP0418_23
