With those steps complete and the basic vehicle assembled, I primed and preshaded the hull and turret, using a Tamiya dark gray on those areas I wanted dark, and Model Master Acryl Steel on those I wanted light - mainly raised areas, panel lines, and edges. Then I applied the green, black, and brown camouflage, using Tamiya's new NATO colors. Following that, I did a bit of post-shading with lightened versions of all three and airbrushed on a bit of mud.
The kit decals went on well; I used Polly Scale clear acrylic flat to hide the clear film. Once I had the decals on and the tools and other details installed, I applied a wash of Grumbacher burnt umber oil paint thinned with Turpenoid. When that dried, I dry-brushed the entire vehicle with burnt sienna and medium gray oil paints, then added dust via pastel chalks. I sprayed Tamiya Flat Black around the engine exhaust grille on the left side. Finally, I painted the windows, tail lights, and other glass with appropriately colored enamels - and yes, the windows really are metallic blue. (I did not add the orange reflectors to the sides, the red reflectors to the hubs, or the red-and-white decals to the front fenders, as I wanted more of an in-service look, and I haven't decided which unit insignia to apply.)
I got most of the information I used from the Army Technology website (
army-technology.com) and the PzH 2000 site (
pzh2000.com). (Did you know that a PzH 2000 can fire 12 rounds per minute, or that its shells can travel as far as 40 kilometers? Yikes!) In fact, it was after one visit to pzh2000.com that I began to suspect that I had not followed the painting instructions closely enough - it appears that the camouflage is factory-applied, and all vehicles get the same scheme.
Overall, I'm pleased with this model. It's big - the hull is a good inch longer than that of an M48 Patton. The basic kit is sound enough for relatively new modelers, and it's scaled well enough that a more experienced modeler can use it as the basis for a superdetailed model. Plus, it looks just plain impressive when it's done.
Terry Thompson
