You have the option of cutting the flaps away and installing them in the dropped position, but step 14's wordless diagram is confusing. It has knife symbols, a question mark, and two Xs over the flaps. Huh? It means cut away and discard the flaps on the wings, then in step 20, you add separately molded dropped flaps. I left my flaps in the raised position.
I had to adjust the shape of the wing fillets for a good fit with the fuselage. The location of the too-thick wing fences is not marked on the wing, and poorly shown in step 13; look at the four-view color and marking drawings for the proper locations.
The horizontal stabilizers have large, strong locator tabs. The landing gear struts are simple and heavy for the scale, and all tires are incorrectly shaped - remove the ridges around the tires. I replaced my main wheels with better ones from my spares box. The main-strut doors are too thick and the main-gear wells are too shallow.
The four-view paint and marking guides are well-done. The decal sheet is comprehensive, but poorly printed; my sample was out of register and had a matte sheen. The white areas were translucent and had a creamy tone caused by the clear carrier film. I ended up using them as masking guides to paint the white markings on my model. In addition to the Red Arrows Hawk, you get Finnish "Midnight Hawks" markings.
I painted my model first with flat white primer, then followed with gloss white for the marking areas and gear bays. After masking the white areas, I airbrushed Xtracolor gloss Red Arrows red. After touch- up, I applied the roundel and lettering decals. They were thin but didn't settle over the raised vortex generators on the wings, so I had to poke holes in them. I replaced the little blade antennas with thinner ones from sheet styrene.
I spent more than 30 hours completing Airfix's Hawk. Experienced modelers will be able to handle the challenges, and all modelers will be happy that there is finally a mainstream 1/48 scale kit of this familiar and attractive aircraft.
Good references are the official Red Arrows website,
www.sky-flash.com/reds.htm, and Aviation Workshop's new book,
On Target Profiles 3 - BAe Hawk in Worldwide Service.- Ross Whitaker
